I wanted to get “157050” from the string “J/157050/0001” using subStr() in AX 2009.
/Ashlesh
/Ashlesh
substr(“J/157050/0001”,3,6);
Thanks for the reply. But it will not help me.
I dont want hard code anything. By using “3” and “6” we are going to hardcode the position and length.
/Ashlesh
Hi Ashlesh,
To get the length, you can use strlen() function.
But if you wish to use subStr() function, you have to let the system know -
If you don’t want to hard code, then you can parameter these two values.
Best wishes,
Hi Ashlesh,
You can also try using ‘TextBuffer’ class. An example from Developers guide -
int pos;
TextBuffer textBuffer;
textBuffer = new TextBuffer();
textBuffer.setText(“ABC DEF GHI JKL MNO ABC ABC”);
pos = 0;
while (textBuffer.find(“ABC”,pos))
print "String found at position: ", textBuffer.matchPos();
pause;
pos = textBuffer.matchPos()+1;
Best wishes,
