Purpose of installing service pack and roll up…after installing ax
Hi samruddhi,
The roll-up carries several country specific functionality & code fixes on various areas.
- We have two different main levels of release: service packs and hotfixes (rollups are just a group of hotfixes).
- In a service pack release we ARE allowed to have a dependency between the kernel and application builds. This means that you can’t mix two different service pack levels or strange things will start to happen in your system.
- In a hotfix release (rollups are just a group of hotfixes) we ARE NOT allowed to have a dependency between the kernel and application builds. This means you can mix any kernel and application hotfix builds - of course you still need to make sure you’re not mixing service packs, so as long as the kernel and application builds you’re mixing were both designed to go on top of the same service pack then you’re ok.
Please go through this link… It might help You…
