use of Record ID in AX?
what is the use of record ID in axapta and what is the difference between record ID and primary index?
As I can recall, the primary use of RecId er the unique identification of a record in the datadase.
Fundamentally as a concept, they are one and same.
Record Id or Record Identifiers - as the term indicates it is identifier for the record.
Primary index by nature is also used as unique reference to a record. The difference in simple terms are -
  1. Primary index is a fundamental RDBMS concept
  2. Record identifier is Dynamics Ax application runtime concept. In fact is the AOS which allocates record identifiers dynamically.
But as I mentioned in the beginning fundamental concept is same. Obviously Record Identifiers can be set up as primary index in Ax tables.
Thanx harish its really helpful…!!
