till now i used to save the values entered in dialog box to tables by clicking ok button and used to retrieve the last inserted values in dialog box using querry.
Now i want to create a new dialog box in such a way that
i just enter the values and dont save them but when i open the dialog box next time i need to get the last values which i entered there…do i need to use pack or unpack?
pls provide me with code…or any example having this kind of code.
If you want to create a dialog which would input your value and then show it next time with the same value or to persist with data, then you can use pack and unpack methods.
This you can find in standard functionality in Item BOM Type:
