Use of Copy Journal s
HI,
I gone through the manual, I could not understand .
Difference between the copy from All , copy from Journal in Purchase order and sales order.
Please throw some good explanation on this to know about this.
Thanks and regards
In AX you have the ability to use the function to create a credit note against the original invoice - this is not a process I agree with and would prefer a new document applied to the invoice. However if you do this the constituent make up of the lines are altered, then when you go to the copy from journal these lines are visible. So invoice an order, then use functions and create credit note and then look in teh copy from journals and you will see it.
With the copy from all you see everything, so that is the difference.
