In a report, I want to use the tempory path (Tools - Option). Do you know then syntax for the ENVIRON function.
ENVIRON(‘TEMP’) returns the path that the environment variable TEMP points at. I think that should be the same path as in Tools->Options (Unless You have used TEMPPATH in the command line)
