1)Can we access Oracle Database to get data through Navision 3.7? 2)Can we access Navision Database to get data from application having Oracle as the backend? This is with repsect to both Propreitary and SQL Server 2000. Thanking you
Originally posted by beena156 - 2005 Mar 11 : 10:01:11
You should have a look here: http://www.databackbone.com/ Search for “universal edition”
You can use ADO library functions in navision to access oracle database and using C-ODBC/C-front you can access navision data from other applications. Cheers
