It said we need to run the impact analysis tool but not sure where to find it either in rich client on in AOT? Can some one help me with the steps if any body had already upgraded?
You should run all the steps in software update check list
Redeploy Deploy updated reports to a report server
Update Enterprise Portal (if you are using it)
Update Retail (if you are using it)
1- Software update check list
2 - Redeploy Deploy updated reports to a report server
3- Update Enterprise Portal (if you are using it)
4 - Update Retail (if you are using it)
