I’m working with upgrading NF 1.1 to NF 2.6. Can I use the Merge Tool for it? I have tried with Merge Tool before but never succeded. Can someone give me advise?
Ouch!! There is no direct upgrade from 1.10 to 2.60 You will have to step through 1.3 2.0 etc: Running the upgrade codeunits at each stage. you do not have to replicate your code changes at each stage just add your new fields then add your code changes to the 2.60 version Test well that the changes work with the 2.60 Version. Allow enough time for the upgrade to step through the versions. David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
Ohh…I was unclear. I understand u can’t go direct from 1.1 to 2.6. The problem was I couldn’t use Merge Tool from 1.1 to 1.2, maybe I don’t understand the description in manual. Today I use Compare Tool to upgrade.
