Upgrade Toolkit
Hi all, Is anyone has done the Navision upgrade from 301B to 3.7 ? If you do, can I know the step to upgrade using Navision developer toolkit ? We do have successfully compare two verses, but when I try to merge the problem appear, so we got to compare and merge… after that we successfully put every object we want to merge to the new modified version 3.7. and then we also successfully create the text file from the new modified version. But when we try to import the object from the text file, my developer license dont allow me to create every object under Id 50000. So how to handle this things [xx(][:(!][V][8]
You must be kidding - see other replies (and stop spamming [;)])
Search forum to get more replies! I would suggest you to import these objects in the Navision standard database with standard objects (demo database with CRONUS).
quote:
Yes, and please in the future post your answer only in one forum. Most of users use Active topics feature so with one post will be enough.
