Has anyone upgraded from NF 2.00C to Navision Manufacturing 2.01B. Are there any issues, problems etc.
Hi, It should not be problem from technical point of view. But you will need setup NM and it can spend a lot of time. When you upgrade from NF → NF you can start work immediately. If you will upgrade NF → NM you will need a lot of setup and training before you start use it (I think 1-3 month). Also if you made some modification for manufacturing functionality in NF it is better not transfer them. Valentin Gvozdev BMI Inc.
