Hi Everybody,
The current me being executed upgrade report NAV 5.0 to NAV 2013 everything okay. But problem function export to Excel in
Section (NAV 5): Header, GroupHeader,Body, GroupFooter. I do not see them when upgrade NAV 2013.
So I will complement them on where in report NAV 2013.
Please solution.
Best Regards
Dinhson
You mean Export to Excel is not available after upgrading to NAV2013?
Did you use CurrReport.PREVIEW statement any where in NAV report?
Hi Mohana,
Please view attachments. All function here is not available after Upgrading to NAV2013, Report when run will export direct to Excel and not use function CurrReport.PREVIEW.
Hi Mohana,
Thanks very much
Did you use Create Layout suggestion to Upgrade report or manually upgraded?
Hi Mohana,
Please view file attached all function here not available after upgrading to NAV2013.
Thanks very much.
Hi Mohana
I import report (object) to NAV and later use function Upgrade Report in Tool NAV 2013. This means that cause manually?
BR
If you simply do above steps it wont upgrade 100%.
it will simply upgrade 10-20% only.
we have to develop ourselves remaining 80-90% like grouping and all
Hi Mohana,
How to optimize more, Please share solution.
Thanks very much.
