Upgrade Nav 2009 to 2013 Spain
Good morning,
I’m doing a migration from 2009 to 2013 in Spain and do not know if I have to use the upgradetoolkit / data conversion tools or Local Objects.
Please, someone could help me?
if you got customized objects, then you need to use the upgrade toolkit.
I have already migrated all code modified client objects. Now I have to pass the data converter. I have the Spanish version. In the Nav cd 7 appear upgradetoolkit folders, data conversion tools and local objetcs. In data conversion tools Upgrade601700.1.fob see this file. In Local objetcs Upgrade601700.ES.1 appears.
What to use?
if its a localized version,use the objects under local objects folder
if its a localized version,use the objects in the local objects folder
