Upgrade NAV 2009 R2 to 2013 R2
Can the rapidstart function be used for upgrading Nav 2009 R2 to 2013 R2.
If yes, how this can be done and whether all data (master data and posted transactions) can be uploaded to Nav 2013
I suggest to take a look at upgrade toolkit, which is the official method reccomended for upgrading: toolkit
Do you have any particular requirements?
the company wants to upgrade from Nav 2009 R2 to Nav 2013 R3. No customisation has been done except for reports in Nav 2009. hence, wanted to know whether the upgrade can be done through RapidStart.
the link provided pertains only to data upgrade, in the done scenario does the application code upgrade should be done?
Here the walkthrough to upgrade the code.
If you want to follow those indication you don’t need to use RapidStart and spend time creating configuration packages and worksheets, just work to merge your modification in order to generate an object set to import after converting your database to NAV 2013 R2.
