- Taken back up of Ax 4.0 DB back up and Ax 4.0 application files
- Created New Db
- Installed the AOS Instance
- Installed Ax 2009 SP1
- and Ax 4.0 application files are Pasted in “C:\Program Files\Microsoft Dynamics AX\50\Application\Appl<Instance Name>\old
- Now started AOS
- Opened AX application
7.1 compile application
Step by step I went in check list
I got Data upgrade cockpit , and I run that jobs in Pre and post synchronization
And detect code upgrade conflicts I run that one also, after completion of this part I am reopened the ax application but it’s showing the only sys and syp layer files . I am not found VAR,BUS,CUS layer customizations
Can any one help me ?.
my customization in VAR, CUS, BUS,User layers
