Upgrade from Ax-4.0 to Ax-2009
Hi I m upgrading from Ax4.0 to Ax5.0. When i doing Synchronization database , it is giving the following error:
Object Server 02: The database reported (session 3 (Admin)): [Microsoft][SQL Native Client][SQL Server]Either the parameter @objname is ambiguous or the claimed
@objtype (COLUMN) is wrong… The SQL statement was: “SP_RENAME ‘“DBO”.PROJTABLE.PRINTMODULETYPE’,‘DEL_PRINTMODULETYPE’,‘COLUMN’”
I can not able to figure out the issue. Plz Help me…!!!
Plz help me out …
I’ve never met this problem. What about to rename it manually?
