Upgradation of AX 2012 R2 to AX 2012 R3 in the same server
I need to upgrade AX 2012 R2 to AX 2012 R3 in the same server.
Can anyone please suggests me the steps to follow for upgradation.
Are there any steps for code upgradation?
If i take the application db and model db backup is that enough before starting with upgradation? Or do i need to do any other things.
For SSRS reports should i need to take backup of Report servers dbs also?
Please can anyone help me as i am confused.
Thanks in advance,
Malashri
The process is well-documented by Microsoft: Scenario: Perform in-place upgrade to AX 2012 R2 or AX 2012 R3. You should use a search engine to find documentation.
(Question moved to the Technical forum.)
Hi Martin,
Thanks for you quick reply. I had already went through the link which you sent.
Also refered the link http://www.msdynamicsax.info/2014/05/ax-2012-r2-to-ax-2012-r3-upgrade.html
Cheers,
Malashri
