Hi, To update your FILE record in Navision, set a different filter and find something, anything. After that you can reset (set again) your filters and your record is updated. Sample files.setrange(path, 'c:\foo\bar\'); repeat if files.find('-') then movefile; until foo = bar;
The find will ALWAYS find the same file. Change your code to: Sample repeat files.setrane(path, 'c:\'); files.find('-'); files.setrange(path, 'c:\foo\bar\'); if files.find('-') then movefile; until foo = bar;
And you’re on!
