I have resolved the issue.
Below is the code for DIXF Class:
In the InsertUpdate method of “DMFPriceDiscAdmTransEntityClass” i.e. standard DMF class for TradeAgreement journals
update the standard code as below:
// N Developed by v-prangu for CBD_IN_015_TRA_TradeAgreements on 09/07/2015
public
Common insertUpdate(Common _target, boolean _callInsertLogic = false, boolean _callValidateLogic = false)
Common ret;
PriceDiscAdmTrans priceDiscAdmTransLoc;
InventDim inventdimLoc;
PriceDiscJournalName priceDiscJournalName;
PriceDiscTable priceDiscTable;
if (entity.MyFlag== 0(true))
select forUpdate
join
inventdimLoc
where
priceDiscAdmTransLoc.ItemRelation == entity.ItemRelation &&
priceDiscAdmTransLoc.AccountRelation == entity.AccountRelation &&
priceDiscAdmTransLoc.Currency == entity.Currency &&
priceDiscAdmTransLoc.UnitId == entity.UnitId &&
priceDiscAdmTransLoc.QuantityAmountFrom == entity.QuantityAmountFrom &&
priceDiscAdmTransLoc.QuantityAmountTo == entity.QuantityAmountTo &&
priceDiscAdmTransLoc.ToDate == dateNull() &&
priceDiscAdmTransLoc.InventDimId == inventdimLoc.inventDimId &&
inventdimLoc.InventSiteId == entity.InventSiteId &&
inventdimLoc.InventLocationId == entity.InventLocationId ;
select OriginalPriceDiscAdmTransRecId, RecId from
priceDiscTable
where
priceDiscTable.OriginalPriceDiscAdmTransRecId == priceDiscAdmTransLoc.RecId;
priceDiscJournalName = PriceDiscAdmTable::find(priceDiscAdmTransLoc.JournalNum).JournalName;
this.MyMakeJournal(priceDiscJournalName, priceDiscTable.RecId); //Create a new method, code for this is after in the end.
if (entity.AccountRelation && entity.MyFlag!= 0(true))
if
(VendTable::find(entity.AccountRelation).AccountNum)
target.relation = PriceType::PricePurch;
_target = target;
else if
(CustTable::find(entity.AccountRelation).AccountNum)
target.relation = PriceType::PriceSales;
_target = target;
if (entity.MyFlag == 1)
ret =
super
(_target, _callInsertLogic, _callValidateLogic);
return
ret;
public
void
CBDMakeJournal(
PriceDiscJournalName _priceDiscJournalName,
recId _priceDisctableRecId)
PriceDiscAdmTrans priceDiscAdmTrans;
RecordInsertList priceDiscAdmTransInsertList =
new RecordInsertList(
