UPDATE TABLE Differences between four parts of code
I started a new job as a AX Programmer and i have a lot of questions which aren’t exactly answered in web…
My first task is to create a class/job which update a lot of tables from hardcode data…
What are the differences between this four part of code… Because in my develop instance all works perfectly
1
static void Job(Args _args)
ARP_HD_Books book;
book.AuthorFirstName = “FIRSTNAME”;
book.insert();
2
ARP_HD_Books book;
select book;
book.insert();
3
ARP_HD_Books book;
select forUpdate book;
book.insert();
4
ARP_HD_Books book;
ttsBegin;
book.insert();
ttsCommit;
First u learn about SQL query and use debugger then u can analysis how code executing. see this link msdn.microsoft.com/…/aa883417.aspx
Plss tell ur fields of the table and how many record were present in ur table.
Tell ur Scenario clearly
I have to add record from hardcode data(which will be inside Job/Class, i know this is !BestPractise but i have to do this)…
I read a lot of forums and blogs and there are examples in various possibilities… I tried several and didn’t see any differences…
This is the reason of my post :slight_smile:
Know i found that in:
1 ### Creates a new record with only AuthorFirstName filled ‘FIRSTNAME’, and all other fields blank
2 ### Creates a new record with only AuthorFirstName filled ‘FIRSTNAME’, and all other fields having the same value as the first record in the same table.
3,4 ### the ttsBegin, ttsCommit is only for Update/Delete command…
