Update statement in job
Hi
I have SQL updates which has to be written in X++ .
–Update Inventory Item Name ------------------------------------------------------------------
Update #P0000 set #P0000.Txt = Name
from #P0000, InventTable, EcoResProductTranslation ERPT where
InventTable.Product = ERPT.Product and
#P0000.EmplItemId = InventTable.ItemId and InventTable.DataAreaId = @Entity and
ProjTransType = 4
–Update Employee Name ------------------------------------------------------------------------
Update #P0000 set #P0000.Txt = HWCD.Name, EmplItemId = PersonnelNumber
from #P0000, HcmWorkerCubeDimension HWCD where
#P0000.Worker = HWCD.RecId and --HWCD.DataAreaId = @Entity and
ProjTransType = 2
I wrote a job as follows:
while select * from _ecoresproductranslation join product from _inventtable
join EmplItemId from caeprojtransposting
where _ecoresproductranslation.Product == _inventtable.Product && _inventtable.ItemId ==
caeprojtransposting.EmplItemId && caeprojtransposting.ProjTransType == 4
while select forupdate caeprojtransposting join ItemId from _inventtable where _inventtable.ItemId ==
caeprojtransposting.EmplItemId && caeprojtransposting.ProjTransType == 4 && caeprojtransposting.Txt ==’’
ttsBegin;
caeprojtransposting.Txt = _ecoresproductranslation.Name;
caeprojtransposting.update();
ttsCommit;
//Update Employee Name
ttsBegin;
while select forupdate caeprojtransposting join RecId from _HcmWorkerCubeDimension where _HcmWorkerCubeDimension.RecId ==
caeprojtransposting.Worker && caeprojtransposting.Txt==’’ && caeprojtransposting.Worker != 0 && caeprojtransposting.ProjTransType == 2
caeprojtransposting.Txt = _HcmWorkerCubeDimension.Name;
caeprojtransposting.EmplItemId = _HcmWorkerCubeDimension.PersonnelNumber;
ttsCommit
First update works but the second update doesn’t works. I am not sure whether the above code is correct.;
ProjTransType = 4
There can be multiple translations for product depending on the language. (I am just typing the code here). You can convert into a update_recordset.
while select forupdate #P0000 // replace #P0000 with table name
where #P0000.ProjTransType == ProjTransType::Item
join ItemId from inventTable where inventTable.ItemId == #P0000.EmplItemId
join Name from EcoResProductTranslation where EcoResProductTranslation.Product == InventTable.Product
&& EcoResProductTranslation.LanguageId == ‘en-us’ // replace it with the required language
#P0000.Txt = EcoResProductTranslation.Name.
#P0000.update();
Your second statement looks fine. Try debugging.
Use ProjTransType::Hour instead of directly using the value 2.
Thanks Kranthi
I have changed and written the second statement but it doesn’t update.
while select forupdate caeprojtransposting where caeprojtransposting.ProjTransType == ProjTransType::Hour join RecId from _HcmWorkerCubeDimension
where _HcmWorkerCubeDimension.RecId == caeprojtransposting.Worker &&
ttsBegin;
ttsCommit;
the value in HcmWorkerCubeDimension → recid takes as empty. But when I query it SQL ,it has the value.
Can we query from HcmWorkerCubeDimension or its not allowed for x++
Please use Insert > Insert Code to paste source code. It keeps indentation and doesn’t add extra spaces between lines, which makes the result much more readable.
Here is your code after I manually added all the lost indentation:
          && caeprojtransposting.Txt == ''
    ttsBegin;
    ttsCommit;
But I would refactor it to something like this:
while select forUpdate caeProjTransPosting
    where caeProjTransPosting.ProjTransType == ProjTransType::Hour
       && caeProjTransPosting.Txt == ''
       && caeProjTransPosting.Worker != 0
    join RecId from hcmWorkerCubeDimension
        where hcmWorkerCubeDimension.RecId == caeProjTransPosting.Worker
    ttsBegin;
    caeProjTransPosting.Txt = hcmWorkerCubeDimension.Name;
    caeProjTransPosting.EmplItemId = hcmWorkerCubeDimension.PersonnelNumber;
    caeProjTransPosting.update();
    ttsCommit;
If I look at the code, it’s clear that you’re trying to use values of Name and PersonnelNumber fields, which you never select from database. That’s clearly a bug. Let’s change the code to this:
    join Name, PersonnelNumber from hcmWorkerCubeDimension
    ttsBegin;
    ttsCommit;
Give it a try and don’t forget to use the debugger if something doesn’t work as expected.
Thanks a lot Martin.
I did not notice that and thought I have added Name in the query.
Now it’s working
