update costprice on SO with Unitprice on PO
Hello,
Is there a way when I update the unitprice on PO(purchorder),it should update the Costprice on SO(salesorder) . Please share me your thoughts. Thanks.
Thanks in advance!!!
If they are directly related it will through the Direct Delivery. You can also use marking and mark the PO to the Sales order - these will flow the costs through although you might not see this instantly on the form, it would take an inventory close (you would need to check) otherwise you need to obey the financial costing chosen by your business and the configuration of elements like the dimension group.
