Hello, I’m trying to use without success the Navision Developers Toolkit to know where some Sumindex are used. Is there any way to know what are the objects that do not work if you disable or delete them? Thanks Marco
That is by try and error only. Because it mainly depends on what parts of Navision (and what reports) you are using. Just disable the key and try to see what happens.
