Hi all.
Can someone explain to me how can i unregister quantity for line in PO (Purchase Order) with code. It is urgent so i will be grateful for any answers.
Hi all.
Hi Tyto,
Please see the Clicked method of the form InventTransRegister /Design/Group:RegisterNowGroup/ActionPane:ActionPaneRegisterNow/ActionPaneTab:ActionPaneTabRegisterNow/Button Group:RegistrationActionsGroup/Button:ctrlUpdateButton
Hi Ishak. Thank you for you reply. Do you think that all the process i being done in the clicked method(). I have seen it and there is pretty big piece of code
Hi everyone. I have found my solution. The key is to use the InventTransWMS_register class. Here is the job with whom I have tested it, and it works.
static void testUnregistration(Args _args)
PurchTable purchTable;
InventTrans inventTrans;
InventTransOrigin inventTransOrigin;
PurchLine purchLine;
InventDim inventDim;
TmpInventTransWMS tmpInventTransWMS;
InventTransWMS_register inventTransWMS_register = inventTransWMS_register::newStandard(tmpInventTransWMS);
while select purchLine where purchLine.PurchId == this.PurchId
select inventTransOrigin
where inventTransOrigin.ReferenceId == purchLine.PurchId
&& inventTransOrigin.ItemId == purchLine.ItemId;
while select inventTrans
where inventTrans.InventTransOrigin == inventTransOrigin.RecId
select inventDim where inventDim.inventDimId == inventTrans.inventDimId;
if (inventTrans.StatusReceipt == StatusReceipt::Registered)
inventTransWMS_register.createFromInventTrans(inventTrans, inventDim);
inventTransWMS_register.updateInvent(purchLine);
P.S. Thanks to Ishak for his reply.
