I’m trying to add a number of unit conversions to different items from a CSV through X++. There seems to be a class built into AX to do this called unitofmeasureunitconversion which can take unitofmeasureunitconversion_conv through a parm method.
In most cases like this there is a class that can be run which will then add this to the tables but in this case I’m struggling to find it.
There is a class called unitofmeasureunitconversionservice but this doesn’t seem to contain a method to do this. Does anyone know if there is a class to add unit of measure conversion built through these classes or will it need to be done through table inserts?
