Unit amount rounding precision in General ledger setup.
Could any expert please explain about the use of the field .
Because even I change the value 1, 0.01 , 0.001 In purchase order line direct unit cost field I could not get any difference.
So please explain about how to use this field
What have you set the Unit Amount Decimal Places field to? This works in tandem with the unit amount rounding precsion, so if you have this set to 0.001 and the decimal places to 0 it will round to an integer despite your rounding precision setting.
Basically the field does what you believe it does, it sets the decimal places on the unit amounts throughout the system, there is one on the currency table as well.
