Am using Ax 2012. With the help of Random and RandomGenerate class we can create random numbers,but that is not unique. I want the random numbers to be unique. is there any way to achieve it…?
Thanks in advance.
Thanks in advance.
Please have a look on the below link
http://axdaily.blogspot.in/2010/01/generating-random-number.html
First Create one Table Name it as RandomTable and Create one Integer Field in this and Name it as Values. Then Try this in ur Jobs.
RandomGenerate r = new RandomGenerate();
RandomTable randomTable, randomTableInsert;
boolean Entry;
int i,counter;
void Generate()
i = r.randomInt(1, 40000); // Set the Limit
do
Generate();
select firstOnly randomTable
where randomTable.Values == i;
if (!randomTable)
randomTableInsert.Values = i;
randomTableInsert.doInsert();
Entry = true;
break;
else
Generate();
counter++;
if(counter == 10)
info(“Increase the Number Limit”);
break;
}while (Entry == false);
