Unexpected Error in Enterprise Portal ?
When i click a particular page,i am getting following error.But this page is working fine for all other users.This particular user have all the rights as what all other users have.
An unexpected error has occurred.
Specified argument was out of the range of valid values.
Parameter name: index
System.ArgumentOutOfRangeException
at Microsoft.Dynamics.Framework.Data.Ax.DataSetView.SetCurrent(Int32 index)
at AxWebUserControl.axGridView3_RowDataBound(Object sender, GridViewRowEventArgs e)
at System.Web.UI.WebControls.GridView.CreateRow(Int32 rowIndex, Int32 dataSourceIndex, DataControlRowType rowType, DataControlRowState rowState, Boolean dataBind, Object dataItem, DataControlField[] fields, TableRowCollection rows, PagedDataSource pagedDataSource)
at System.Web.UI.WebControls.GridView.CreateChildControls(IEnumerable dataSource, Boolean dataBinding)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxGridView.CreateChildControls(IEnumerable dataSource, Boolean dataBinding)
at System.Web.UI.WebControls.CompositeDataBoundControl.PerformDataBinding(IEnumerable data)
at System.Web.UI.WebControls.GridView.PerformDataBinding(IEnumerable data)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxGridView.PerformDataBinding(IEnumerable data)
at System.Web.UI.WebControls.DataBoundControl.OnDataSourceViewSelectCallback(IEnumerable data)
at System.Web.UI.WebControls.DataBoundControl.PerformSelect()
at System.Web.UI.WebControls.BaseDataBoundControl.EnsureDataBound()
at System.Web.UI.WebControls.CompositeDataBoundControl.CreateChildControls()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxGridView.CreateChildControls()
at System.Web.UI.Control.EnsureChildControls()
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
