Have anybody created an Undo function for Transfer Shipments?
pls let me know how dis could be done in navision…
Yes,we did
What problem you are facing in creating this?
waw…there is no inbuilt fuctionality for undo shipment in navision…bcoz of that i`m asking you…pls explain me with coding detail and also where we need to modify the code unit…
What did you try as of now?
You can use Item reclassification journal and write code accordingly to undo the shipment.
