Hi
I want to underline a control based on condition in a form , when it is executed to open.
for example : i want to underline emplid in Employee form
any idea ??
Hi
any idea ??
Hi Manish,
For using Underline you have write the Following code where ever you need…
emplid.underline(true);
Make sure AutoDecleration Yes for Emplid Control in Design Part
HI Saadullah,
thx for reply,
But where do i apply emplid.underline(true); , so that when form open based on some condition it will underlne or not underline emplid
pls help
what is the condition? i mean at the time of opening the form or at the time of editing a record…
tell us the condition so that we can suggest where to write the code?
Thanks to both of you for taking interest on this topic.
Well, i wrote a private method on the datasource and called it on Active , thus find solution
