Under delivery of line is 92.8% but allowed under delivery is only 0.00% PO AX 2012 FP
Hi I have two lines in the PO of same item - one line is already received and invoiced. When the user try to receive the item, the system threw an error message:
From procurement sourcing parameters, I haven’t ticked accept over and under delivery;
Safety level of invoiced orders - none
From released product form - over and under delivery of that item is 0.00
What could cause this error? how to over come this?
thank you
Well you have not activated it so you do not accept under-delivery :slight_smile:
From memory you need to either set the line under delivery, pretty sure the close flag is not on the line if you do not accept under delivery, but if it is tick it on the short delivery, or dont and then use deliver remainder.
