Unable to view PO print if fully invoiced
If Po is fully invoiced in inquiriesbutton Purcahse order doesnot have line, it is getting deleted. How to see the preview of PO?
Rgds,
Srini
No lines or nothing to print? As standard the invoice when posted is ticked will write to the inquiries and nothing touches this. I would suggest a related modification here causing you issued.
Does your PO gets deleted after invoice?
No lines in overview tab and lines tab
PO doesn’t get deleted only not able see the preview of PO from inquires!!!1
Then there might be some modifications to standard as Adam mentioned previuosly.
Thanks i will check…
