UNABLE TO UPOLAD DOC IN ENTERPRISE PORTAL
Hi, when i try to upload doc in EP,i’m getting the error as “The folder C:\temp\ specified for the document type does not exist”
See into your Document Management Setups. Basic → Setup → Document Management.
Go to Document Types and select your document type and see the Archive Directory → whether the specified path exists or not.If it does not exist change the path and try again.
Hey rajeshwari,
I need your help for uploading my MS word document in AX EP 2009.If u have time then please reply me.
Thanks & Regards
Arun Garg
Check whether the path exists in which your doc gets saved,
Please check the Table properties in the dataset used by ‘EPDocuFileAdd.aspx’,the size of the file which you are trying to upload.
-Rajee
How to upload any document in EP ??
