taty
April 2, 2014, 2:52am
#1
Hi ,
We need to run MRP for Company A, Company B and then run Intercompany Master scheduling.
However when we try to run manually Intercompany Master scheduling , we have this message:" The plan MasterPlan is not selected as the dynamic master plan in company A. Net change or Net change minimized cannot be selected". Any idea ???
Check your intercompany planning group configuration and ensure the intercompany plan is defined correctly.
taty
April 2, 2014, 3:26pm
#3
Hi Adam,
I just checked and this is what I have:
in the Intercompany planning group members tab
Legal Entity Scheduling Sequence Master Plan Automatic Copy to dynamic plan
Company A 10 Master Plan Yes
Company B 20 Master Plan Yes
So when I try to run Intercompany master scheduling and I have the error message.
So check the Master Plan Master Plan is configured for Company A in the Plan form and the Intercompany fast tab
taty
April 2, 2014, 6:06pm
#5
In the company A, I checked Setup/ Plans/ Master Plans and this is what I have:
Intercompany Planning Fast Tab
Include downstream planned Intercompany demand – Yes
Downstream source plans — Company : A Master Plan = Master Plan
In the company B, I checked Setup/ Plans/ Master Plans and this is what I have:
Downstream source plans — Company : B Master Plan = Master Plan
I dont see anything wrong , any idea?
Well assuming the Dynamic Master Plan is MasterPlan in company A I can only suggest you get a developer to debug because I cannot see what is wrong given the description.
taty
April 3, 2014, 3:56pm
#7
Hey Adam, just to make sure I understand what you say : what do you mean by " Well assuming the Dynamic Master Plan is MasterPlan in company A" ?
In the parameters there is a “Dynamic Master Plan” field - this has to be your “MasterPlan” as per the error message AX is telling you.
taty
April 4, 2014, 2:55pm
#9
Ok. Agree . I have that setup done. After debugging it looks like I cant run MRP Interco with “regenerative” in both fields. Am I right?
If that is the debug limitation I guess so, but if I was you I would ask MS why.
taty
April 5, 2014, 12:23am
#11
That is exactly what i 'm going to do. Thanks[:)]
