Unable to Print an RFQ
Hi ,
I am trying to print an RFQ and this is the message that I have:
Error executing code: The field with ID ‘0’ does not exist in table ‘PurchRFQTable’.
Stack trace
(S)\Data Dictionary\Maps\SalesPurchLine\Methods\amountExclTax - line 50
(S)\Data Dictionary\Tables\PurchRFQLine\Methods\amountExclTax - line 3
(S)\Data Dictionary\Tables\PurchRFQParmLine\Methods\amountExclTax - line 14
(S)\Data Dictionary\Tables\PurchRFQParmLine\Methods\lineAmountExclTax - line 5
(S)\Classes\PurchRFQSendJournalCreate\calcLine - line 6
(S)\Classes\PurchRFQSendJournalCreate\createJournalLine - line 7
(S)\Classes\FormletterJournalCreate\createJournalLines - line 24
(S)\Classes\FormletterJournalCreate\createJournal - line 19
(S)\Classes\FormletterJournalCreate\run - line 6
(S)\Classes\FormletterService\createJournal - line 29
(S)\Classes\FormletterService\run - line 75
(S)\Classes\FormletterService\postRequestForQuoteSend - line 14
(S)\Classes\DictClass\callObject
(S)\Classes\SysOperationServiceController\runOperation - line 93
(S)\Classes\SysOperationServiceController\runServiceOperation - line 22
(S)\Classes\DictClass\callStatic
(S)\Classes\SysDictClass\invokeStaticMethod - line 26
(S)\Classes\SysDictClass\invokeStaticMethodIL - line 39
(S)\Classes\SysOperationRPCFrameworkService\runServiceOperation - line 5
(C)\Classes\SysOperationServiceController\runOperationWithRunAs - line 7
(C)\Classes\SysOperationServiceController\run - line 22
(C)\Classes\FormLetterServiceController\run - line 3
(C)\Classes\PurchRFQFormLetter\run - line 14
(C)\Classes\PurchRFQFormLetter\main - line 47
(C)\Classes\FormFunctionButtonControl\Clicked
I dont know how to solve it. Is is a setup issue, a bug. Please any help will be appreciated. Thanks
What’s your exact version of AX? Can you get a developer to rebuild CIL and review what happens at line 50 in SalesPurchLine.amountExclTax()? What I see in the standard AX2012 R2 is code that shouldn’t be called, therefore either it hasn’t been not built correctly, you’re using a different version or your application has been customized.
