Unable to open objects.
Hi ! What can be the problem? We have exported some objects from Nav4 because we want to use them and to add some modifications. But when trying to open those objects now, we are unable as the system doesnt allow us to do that. Any idea???
Are you importing as text or as fob? As a customer you are not allowed to import text if I remember correctly. What is it exactly you are doing and what is the exact errormessage?
Hi Shanna, could you please update your Profile with some information about your self. At the minimum, to be able to help you properly, we would at least need to know Member Type: are you an end user, NSC consultant, Developer etc. It will help you a lot if you get answers that target your actual need I am sure you will agree. [:D]
In fact , i’m trying to import tex files instead of fob files into Navision. That’s was my mistake. Thanks.
