Unable to insert record in Item Details
I get the below given error whenever I try to create a record in Ax 2009 in a particular company.
Cannot create a record in Inventory module parameters (InventTableModule). Item number: xxx, Purchase order. The record already exists.
This has been the case ever since a job for importing data into inventtable was aborted abruptly due to some reason and recids were generated by the same reason. But now, we’re not able to reverse the effect, we’ve tried updating records in the table SystemSequences Set NextVal column where tabid = 175. Is there anything more I need to do?
Hi Abhinay,
I am getting similar issue while using DIXF/DMF. Any suggestions please?
