I am faceing one issue in the On hand report in ax 2009 . In Inventory on hand report (Path :: Inventory Management >> Reports >> Transactions >> On hand), when we are executing the report the report figure and transactions details are not getting tallied.
Basically when we run the Inventory on Hand report with Physical date criteria then for the Item one specification the line is not coming.
When I am running the report without criteria then all the transaction even negative inventory are also coming in the report…
please suggest me where the problem ? In physical Date or somewhere ?
You should have a select button which allows you to modify the report’s query, you just have to set “>0” in criteria column an select physicalQty in table fields.
