Hello AX Guys,
I am using AX 2012 R3.
I have two AOS instances on single system.
I have used single reporting service for both AOS and configured properly the Report parameters.
I have already regenerated WCF service without any issue.
I am trying to deploy a report on second AOS using Management shell by following command
Publish-AXReport -reportName ABC -servicesAOSName XYZ -skipReportServerAdminCheck
But i am facing below issue
Unable to connect to a Microsoft Dynamics AX WCF service
Ensure that the Microsoft Dynamics AX AOS has fully started and that the
requested WCF service is available. See the exception message below for
details:
>Metadata contains a reference that cannot be resolved:
’XYZ:0/…/MetadataService’.
Anyone can help me out in this.
