Unable to copy Files in AX 2012
I have written a class to export the data into teh excel before exporting i need to copy old files into the new folder for this i have written the bellow code. but the file is not copying. When i run a job to check the file copy operation it is working but for class it is not working. and the class is running on the client. i have given the file IO permissions also but still no luck.
public static void main(Args _args)
SysExcelApplication xlsApplication;
SysExcelWorkBooks xlsWorkBookCollection;
SysExcelWorkBook xlsWorkBook;
SysExcelWorkSheets xlsWorkSheetCollection;
SysExcelWorkSheet xlsWorkSheet;
SysExcelRange xlsRange;
InventLocation inventLocation;
WinAPI winAPI;
int row = 1;
str fileName, newFileName;
str strdatetime;
date currentDate = today();
container companies;
UtcDateTime dateTime = DateTimeUtil::getSystemDateTime();
FileIoPermission fileIoPermission;
Set permissionSet;
WinAPIServer winAPIServer;
int size;
try
fileName =“G:\filepath\SITE.xlsx”;
//Initialize Excel instance
if (xSession::isCLRSession())
info(‘Running in a CLR session.’);
else
info(‘Running in an interpreter session.’);
//Determines the tier
if (isRunningOnServer())
info(‘Running on the AOS.’);
else
info(‘Running on the Client.’);
if(winAPI::fileExists(fileName))
strdatetime = DateTimeUtil::toStr(dateTime);
newFileName =“G:\FilePath\SITE_”+strdatetime+".xlsx";
permissionSet = new Set(Types::Class);
//get file write permission for createFile
permissionSet.add(new FileIoPermission(newFileName,‘w’));
//get file read/write permission for getFileSize and closeHandle
permissionSet.add(new FileIoPermission(’’,‘rw’));
CodeAccessPermission::assertMultiple(permissionSet);
//invoke protected APIs
//WinAPIServer::createFile(fileName);
if(winAPI::copyFile(fileName,newFileName,true))
info(“File Copied”);
else{
info(“File not copied”);
xlsApplication = SysExcelApplication::construct();
xlsWorkBookCollection = xlsApplication.workbooks();
xlsWorkBook = xlsWorkBookCollection.add();
xlsWorkSheetCollection = xlsWorkBook.worksheets();
xlsWorkSheet = xlsWorkSheetCollection.itemFromNum(1);
//Excel columns captions
xlsWorkSheet.cells().item(row,1).value(‘SITE_ID’);
xlsWorkSheet.cells().item(row,2).value(‘SITE_DESC’);
xlsWorkSheet.cells().item(row,3).value(‘MFG_SITE’);
companies = [“230”,“320”];
row++;
while select crossCompany: companies * from inventLocation where inventLocation.InventLocationType == InventLocationType::Standard
xlsWorkSheet.cells().item(row,1).value(inventLocation.InventLocationId);
xlsWorkSheet.cells().item(row,2).value(inventLocation.Name);
xlsWorkSheet.cells().item(row,3).value(‘NA’);
row++;
// WinApi::deleteFile(fileName);
if(WinApi::deleteFile(fileName))
info(“File deleted”);
xlsWorkbook.saveAs(fileName);
//xlsApplication.visible(true);
xlsApplication.quit();
xlsApplication.finalize();
info(strFmt(“Total number of rows retrived: %1”,row));
catch (Exception::Error)
info(strfmt(“Caught ‘Exception::Error’. %1”, time2str(timeNow() ,0,0)));
i wrote some info to check whether the file is copied are not the info log is as follows.
File not copied //this is the copy operation output
File deleted
Total number of rows retrived: 294
Try this
