Im getting the below error while checking in the labels.
Kindly guide.
Thanks & Regards,
Chutti
Please give us more information. What’s your version of AX? What’s your VCS? When did it start happening? Does it happen for all label files? For all users? For other element types? If you use TFS, what’s the status of the file in the given workspace? Do you have any other information that may be relevant to the problem?
Hi Martin,
Im using AX2012 R2.
Microsoft Visual Studio Team Foundation Server (TFS)
It was working fine so far.Getting this problem for the past two days.
It happens for all label files for specific users(In this case only for me ).
The status of the file is “edit”.
I could not find any other information about this.
Kindly help.
Thanks & Regards,
Chutti
Can you do some tests that don’t require replacing temporary IDs in code? If so, try checking the label file directly from Team Explorer. It might give you an error message explaining the problem.
