Hi Everyone
I have a requirement where I need to add a datasource(Table2) to the form with a join to existing datasource(Table1) and use a field from the newly added datasource to be shown on the grid of this form which can be filtered/sorted.
I tried the following steps
1.Add the new datasource to the form and specify the join source and join type.
- In the init method of newly added datasource, executed addLink method as following specifying the link between the fields
QueryBuildDatasource qbds = this.queryBuildDatasource();
qbds.clearLinks();
qbds.addLink(Table1 field, Table2 field);
But the newly added field value is not displaying properly on the grid. When I filter records based on field of Table1 I can see the Table2 field value but this value is not consistent when i remove the filter I cannot see the value when i scroll or I was not able to do a filtering on the newly added field.
Note: There is already an existing relation on Table1 with Table 2. But in this case i need the data from table 2 based on a newly added field on Table 1 which has recid values of Table 2 I used this in the addLink
Can anyone let me know If i am missing anything or Is there any other way to acheive this.
Thanks in Advance
