when i try to open the Enterprise portal site AX prompts me with an error " no connection could be made because the target machine actively refused it "
Please help.
Rajee
Please help.
Rajee
Hi.
This can be caused by a number of reasons.
I would suggest first making sure the EP is working: try to open the site on the machine that is actually hosting the IIS / WSS. You can then check the firewall running on the AOS server to be Off or to have the proper exceptions setup for the AOS port.
Let me know if the above are setup right and will take it from there.
Iulian.
