Hi all and thanks in advance for any help you can provide.
I have created a dialog that contains an Item number dropdown. When you select the dropdown and click an Item from the dropdown grid it puts in the ItemId and works great when I click OK on the dialog.
My issue is that if i were to just type the ItemId, instead of selecting form the drop down, the text i enter is not being assigned to the DialogField. Is there a way to set the text that is manually entered so the user could type the ItemId or select from the dropdown?
Bob
