Hi, How to install two Navision servers with different DB on the same machine. cheers
Read the “Installation & System Management” (w1w1ism.pdf) manual located in the Doc folder of the Product CD. For MBS-Navision 3.70, this document has the information you require on page 21, chapter 1.6 “Running more than one server”.
Hi Bobby, Just create two folders with different names and install servers in that. Dont forget to give different names to folders. That will Do.
quote:
It’s a little bit more than that to do, so read the manual. It’s all there. You need to specify port numbers and change the services-file.
