Tutorial_EventProcessor
Can someone explain me please what is the purpose of the form : Tutorial_EventProcessor
Does it suppose to flush all emails that are on hold ?
What happens behind the scenes when i press the ‘run’ button?
Yaniv
The forms Tutorial_EventProcessor and Tutorial_WorkflowProcessor are used mainly for demo purpose…
The Tutorial_EventProcessor helps in sending the alerts (May be pop ups or emails depends on the configuration of alerts)
Basically there are two type of alerts one is change based alerts and other one is Due date based alerts which can be seen in the form…
Run will help you in sending the alerts which are of kind Due date based…
But for real time you need to make setups for these alerts in Basic module…( this form will not be used - because every time one need to run it)
