Turn on Lot No.
Currently the customer is having the item master without “Lot No.”. But Customer is requesting to implement the “Lot No.”. how to proceed on this?
Regards
Ramanath
Item has item ledger entries?
Yes. Item ledger entries exists.
Here the solution for the above problem
bring inventory to zero (using physical journal not Item Journal) . Create two batches. Run count phys inventory in each batch. The first one I zero the second one I post once I enable lot tracking. I then put the lot info for the items.
Thank you
Issue Closed.
