Am trying a method, just as a try am having 2 fields in a table. Those fields am having in the form also. The first field is a option field, second one is the code. In the option field am having the options as Item, G/L Account, Resource etc. If am selecting the item option in the first field the caption for the second field has to be changed to ITem & the look up for the second field should go to Item list form if the option i select is G/L Account then the caption should change to G/L Account and the look up for the second field should go to G/L Account.Is There any chance for this method.
Cheers
Seshadri.
