try catch Query
Hello All,
When i’m throwing error from inner try() block i’m not able to catch error in inner catch() block,it is going in outer catch() block?Can anybody tell me exactly what is happening in below code and what is the role of ttsbegin and ttscommit in below code?
try()
//Some code
ttsBegin;
try
throw error("");
catch
ttsCommit;
catch
//some code
Thanks in advance
There is nothing in your inner catch.
This can help you, https://msdn.microsoft.com/en-us/library/aa893385.aspx
It is the standard behavior, please refer to this link and look on the sample 5 https://msdn.microsoft.com/en-us/library/aa893385.aspx
Use the ttsbegin and ttscommit inside the second try statement.
e.g.
try
//Some code
try
ttsBegin;
throw error("");
ttsCommit;
catch
catch
//some code
Use
Hi Kranthi,
Its just a sample,i’m asking about if you throw error from inner try why it is not caught in inner catch?
Hello Hariharan,
I got your point but i’m still not able to figure why its happening,what is the reason behind this behaviour?
Could you please explain the concept in more detail?
Why is it happening? Because that’s how X++ has been designed, therefore any other behaviour would be wrong. The problem is only in your incorrect expectations.
