TRIGGER
Dear all,
When a click event is done in which trigger of the table coding should be written .i.e ( when a menu item is clicked the header table should populate a value. )
With regards,
R.Ramanathan
Please don’t start new thread for same query, you could follow-up in your earlier post on the following link:
http://dynamicsuser.net/forums/t/30219.aspx
I removed the other topic
A menu item is a form control. Any code you want to be linked to the menu item (selecting it using mouse or key short cuts) should be programmed in the OnPush trigger of the menu item. So no code on table level.
